When I record an keyframe animation video from microstation v8i I face an issue like there are some patches visible in the video. The following images are for your reference.
For your information, I have kept display style as :"SMOOTH - SKYSPHERE" and I have kept the default lighting "ON". I am using the following settings for recording the keyframe animation. Can anybody suggest me how many hide to light patches
can anybody suggest me some good settings for video clarity.
Hi Narayan,
Is the image shown on the right from inside the container? You could try setting specular to zero for the material where you are seeing this. This would look much better if you were using current version of MicroStation CONNECT Edition.
Cheers,
Jerry
Hello Jerry,
Thanks for the reply. I have not used any material for this building. I have just applied the color RAL 9011. Is there anything else which needs the attention. I can send the .dgn file which I have used.
Having the dgn would make it easier for me to see what your seeing and make suggestions to fix.
Shall I attach the .dgn file here if you dont mind ?
Try sending it to me in email attachment jerry.flynn@bentley.com
