I have 30,000 reference files, coming from 3.5 Gbytes of i-model data. I need to get that into LumenRT. I have tried building up the scene files gradually, turning on references and exporting to LumenRT step at a time. I got a quarter of the data in before it started crashing LumenRT.
Are there any suggestions for getting large datasets into LumenRT.
I have never done this with this large number of dataset. But maybe you could merge a couple of your reference files together and then put them in LumenRT?
How big in terms of physical size is the model, city block or few hundred feet of a road?
With that many references it will be hard to deteremine if a specific reference is the source of the issue. are there any uniqe things referenced in, like a reality mesh or terrain?
It terms of file size limit for lumen it should be able to handle it.
The site is 1100m long and similar width, so 3600 feet. Packed full of equipment.
Screenshot?
It would work if the dataset could be converted to 3sm format. Unfortunately such converter is used only internally by Bentley.
LumenRT terrain is 4x4 km wide but there are some Bentley demos that long linear road project is imported in LumenRT but again it may be some special version.
