Hi
I do have a problem. I would like to texture part of the wall with the picture of a fresco and another walll with actuall picture of the brick. The old Descrates allowed for wraping the image to the object. I do not see that option here. I was thinking abou cration of a new texture with the image but I have a few problems.
1. Will that not degrade quality of the image
2. How to aplly it in the right place - I do have 3D coodriantes of all edfes of the fresco and I would like to place it in that placec exactly (this is not a flat wall)
Could you tell me how start doing that?
Hi Paulina,
this is Visuallization forum, whereas you question seems to be about Bentley Descartes product.
Can you please follow the community best practices and to specify your product and its version (e.g. build number)?
If your question is really about Descartes, I recommend to move your post to ContextCapture | Descartes | Pointools | Orbit forum. To move existing post to another forum, use More > Move tool available under your original post (do not create a new post).
With regards,
Jan
Hi Paulina, assuming this is meant for the Microstation Rendering forum, You should be able to position the texture by eye applying and manipulating a material projection: Visualization > Home > Materials > Projections
However you are probably going to have to apply the material twice, once for each face and then line up the projections.
I do wish the MicroStation projection tools were more accurate and actually used accudraw to help align texture to be pixel perfect - this is important for building materials like brickwork where setting out and dimensions are exposed as part of the geometric patterning / hiddenline extraction workflows for elevations.
Form the little I've seen, I really liked the tool / kind of control you appear to have in Descartes for accurately placing images as textures.
Rob
Hej Paulina
możesz podesłać przykład zawsze - załączyć . To zobaczymy co i jak
You can add attachments here with example.
Hej/Hi
I was looking for somthing that works like this potion used to: https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/w/wiki/24942/bentley-descartes---raster-texturingBut I cannot find some of those options in the new Descartes. In particular i cannot asigne the raster to the choosen object.
Ah ok understand. I am working on pure Microstation. And this type of texture i am making in Photoshop or use Sketchup photomatch .
Maybe you can find this old in Toolbox menu or by key-in
