I have one of the out of the can material assigned to a mesh element in MicroStation and everything looks great, when I export to LumenRT the material transfers but looks really odd in the model even though the JPEG material looks okay in the element selection.
Any recommendations on how to get the same great material from MicroStation in LumenRT?
Hello Ariel,
what is material mapping type used ? have you tried using other mapping type such as cube , sold ?
will you please share small test case, so i can investigate more on same
Thanks & Rg
Harshad
Thank you for the tip. Changing the mapping type solved the issue.
Ariel
