I have problem with bicycle animation. I prepared Single Lane in ORD and Animation looks quite good. When i went to LumenRT bicycle went only straight. He didn't hold to created single line. Did anyone have problem like this? I used "Omar" character.
ORD
LumenRT:
Hi Jacek,
Here's an explanation of what is happening. The Omarie character has a default LumenRT animation path that needs to be removed in order to see the animation provided by the MicroStation traffic animation tools.
Here are the steps to remove this default LumenRT animation path:
Regards,Ron
Hi Ron,
Tank you very much for help. Right now bicycle animation works excellent.
I'm glad it worked for you!
