Questions on clipping planes in LumenRT:
1. What does the infinite/finite clipping plane option do? It appears to just turn off the clipping plane when I uncheck infinite.
2. I have two objects in a scene, the existing terrain and a new object. The new object is would remove some of the existing terrain, a cut in a hillside for a road, for example. Can I use multiple clipping planes to cut out part of the existing terrain, while still have the new object shown? It's not possible to model the two objects together, as they are coming from different software platforms.
Thanks for any help you can provide.
Steve
Hello Steve,
Did you file a Service request for the same.
I can help you with clipping plane tool.
Please let me know your best possible suitable time.
Thanks.
Rg,
Ankur Ashesh
thibcorps said:1. What does the infinite/finite clipping plane option do? It appears to just turn off the clipping plane when I uncheck infinite.
This option lets you resize the clipping plane so in a situation it acts as a window only clipping a portion of an element rather than its whole cross-section
thibcorps said:2. I have two objects in a scene, the existing terrain and a new object. The new object is would remove some of the existing terrain, a cut in a hillside for a road, for example. Can I use multiple clipping planes to cut out part of the existing terrain, while still have the new object shown? It's not possible to model the two objects together, as they are coming from different software platforms.
If the objects are on different levels a clipping plane can be set to apply to a specific level only see:
file:///C:/Program%20Files/Bentley/Bentley%20LumenRT%20CONNECT%20Edition%20-%20Update%2014/Help/html/GUID-3935D268-73D7-4715-87D8-22BFA65C0790.html?q=clipping
Will it be ok for you tomorrow? any suitable time.
Please let me know, I will sent you the meeting request.
This is your e-mail ID - stephen.c.thibaudeau@usace.army.mil
