I have modeled this light with V8i and assigned material but now can't open material editor. Luxology 20a installed.
I can open the material editor in V8 XM.
Can someone gives help ?
Fabrice
Hi Matt,
I'm not fine. In the task manager I don't see "modo_cl.exe" and after reinstall >> crash again
Is there an other solution ?
I didn't see your log, but if I had crashing material editor, this helped...
Fabrice try to go to Windows\System32 find file FreeImage.dll and rename it to FreeImageOld.dll. After that go to Bentley\MicroStation\mdlsys\asneeded\luxology again find file FreeImage.dll and copy it to Windows\System32
If crashing again, it is not in this file, so you can rename it back and I can't help you :(((
HTH, Dan
Hi Dan,
You saved me ;-)
Great thanks
