ORD to LumenRT Error: Exported Data are malformed
Good day
I'm trying to export a clipped/ masked 3SM in ORD to LumenRT. I've done this several times before, but now I'm getting this error with LumenRT Designer U14:
Error: Exported data are malformed.
I then tried to export the file without any clips or masks and I still get the same error.
I've tried to attached the .4ds file, but I'm getting an error when uploading, so I've included the content of the .4ds file below.
This is the .4ds file with no clips or masks applied:
<?xml version='1.0' encoding='UTF-8' standalone='yes' ?>
<LumenRTSettings>
<ModelName>PE283-3SM-201112</ModelName>
<VOBPath>D:/Documents/Bentley/Bentley LumenRT CONNECT Edition/PE283-3SM-201112/Draft/source/temp.lob</VOBPath>
<FastExport>true</FastExport>
<AutoScaleLighting>true</AutoScaleLighting>
<DynamicSun>true</DynamicSun>
<ExportSource>MS</ExportSource>
<Camera>
<CamFocalLength>115.299</CamFocalLength>
<CamPosition>0,0,6767.8</CamPosition>
<CamVector>-0,-0,-1</CamVector>
<CamUp>0,1,0</CamUp>
<CamRight>1,0,0</CamRight>
</Camera>
<UseVueHeliodon>true</UseVueHeliodon>
<Heliodon_north>0</Heliodon_north>
<Heliodon_altitude>0</Heliodon_altitude>
<Heliodon_latitude>39.9333</Heliodon_latitude>
<Heliodon_longitude>-75.15</Heliodon_longitude>
<Heliodon_date>7/1</Heliodon_date>
<Heliodon_time>10:0</Heliodon_time>
<Heliodon_year>2001</Heliodon_year>
<Heliodon_timezone>-4</Heliodon_timezone>
<LayersTable>
</LayersTable>
<SectionPlanes>
</SectionPlanes>
<BIM>
</BIM>
<ConnectProjectGUID>9db1e1b4-c814-4d3b-884c-4ebb0966ab6b</ConnectProjectGUID>
<ScalableMeshList><ScalableMesh Path = "S:\R&H-Archive\Scalable Meshes\Montrose.3sm" Center = " -30094.98359941,-2816278.06500091,-0" ReprojToSceneMatrix = " 1,0,0,0.0,0,1,0,0.0,0,0,1,0.0,0.0,0.0,0.0,1.0" >
<ClipFile Path = "P:\PE\PE283 - N4 Montrose Interchange Design\3_Working\3-4_DivT\Visualization\Scalable Mesh\PE283-3SM-201112\1121_clips" />
<ClipFile Path = "P:\PE\PE283 - N4 Montrose Interchange Design\3_Working\3-4_DivT\Visualization\Scalable Mesh\PE283-3SM-201112\1121_clipDefinitions" />
</ScalableMesh>
</ScalableMeshList>
</LumenRTSettings>
