Every time a try to export a decent size 3d file to LumenRT I get a "corrupted file error with a possibility of not enough disk space" I have 164GB of room on C:. I tried to export a couple of cubes and that worked fine. I have tried this across a few versions... Help ORD Connect Edition 2020 Release 2 Update 8 10.08.01
Hello Kendezines,
The error msg is for Graphic card.
Which graphic card you are using?
Also if you can share the model with us we can have a look.
Thanks.
Rg,
Ankur Ashesh
This happens across multiple files so it's not file related. I am remote and connote access the setting but I believe it's nvidia...
