I have created a document that could be helpful for those of you trying out the new VUE Rendering engine that is a technical preview in MicroStation CONNECT Edition Update 15. This document covers PBR materials and a few other hidden goodies.
Hope this helps,
JerryPDF
Too bad it is not available in the latest version of Open Building Designer (update 7) ...?
wysiwyg said:Too bad it is not available
It looks like it is available in Open Building Designer (update 7) as a Technology Preview according to the online documentation.
(Technology Preview) Vue Rendering Dialog
Hello Ron,
That's weird?
I'm using update 7 and their is nothing of VUE to be found. Even in the Ribbon Search... result only "VUE (*.vob)"
Is their another manner that I'm not aware of?
Update 7 VUE render is a tech preview meaning it would require a token from us to enable feature. I just talked to developers and OBD Update 8 is going to be released in next couple of days. I would recommend you wait for it, that version is based of MicroStation CONNECT Edition Update 15 and will not require a token.
Cheers,
Jerry
Thanks Jerry!
