I have created a document that could be helpful for those of you trying out the new VUE Rendering engine that is a technical preview in MicroStation CONNECT Edition Update 15. This document covers PBR materials and a few other hidden goodies.
Hope this helps,
JerryPDF
Update 7 VUE render is a tech preview meaning it would require a token from us to enable feature. I just talked to developers and OBD Update 8 is going to be released in next couple of days. I would recommend you wait for it, that version is based of MicroStation CONNECT Edition Update 15 and will not require a token.
Cheers,
Jerry
Thanks Jerry!
