You need either Contextcapture Editor or Bentley Descartes. You just create flat rectangle for surface or use coordination services to download DTM and then create new 3SM and provide the surface and Bing as texture. Unfortunately Contextcapture Viewer doesn't support Reality mesh with Bing and it is not fixed for years. You can use it Microstation only.
