I am trying to add a few people to a rendering that I am making. When I try to use the populate tool and hit the magnifying glass to select content, all of the content is red and cannot be used. Im getting a message on the bottom of the screen that says "No cells are available. . ." Is there supposed to be a library that came with the software?
The image is showing Name(s) LRT-* this prefix is showing that its LumenRT Content and are displayed red as they cannot be found.
If you look in the Message Center you will probably see a message " Cannot find item LRT_Characters_Ani in library c:\programdata\bentley\connectsharedcontent\cellsforlumenrt\lrt_characters.cel "
For installation of LumenRT Content see https://communities.bentley.com/products/microstation/microstation_visualization/w/microstation_visualization_wiki/33677/how-install-lumenrt-content
Carl Myhill
Technical Support Engineer
Bentley Systems
