I am currently using MicroStation connect version 14 with LumentRt and have seen many videos on the web where you take a 2d dgn file and bring it into google earth and export it to a 3d kmz file but this does not include the profile and superelevation of the roadway..
In my situation I have a typical roadway section 12’ tw and 8’ shld Lt and Rt side with a centerline profile and a superelevation and existing terrain data.(dtm) files in dwg and dgn.
How do go about adding this to a 3d dgn then importing this to LumenRT using Microstation Connect.or c3d.
Appreciate the steps to accomplish this.
www.youtube.com/watch
Can anyone provide me a work flow on what files are needed from c3d 2016/2020 to MicroStation connect version 14 dgn to LumenRT specifically roadway design.
Thanks.
MicroStation V8i (SELECT series 3) - Version 08.11.09.578
Microstation Connect 10.14.00.109
Can anyone help me with this either import microstation connect files or c3d files into Lumenrt
Export corridor solids, import into microstation, (onto a 3D seed) add material to components (visualisation tab) then export to lumenRT (visualisation tab), be sure to at least use a workspace/workset (maybe metric or imperial)
