I am trying to import an InfraWorks model into Lumen RT with an FBX import. All 3D InfraWorks elements align well with the Lidar based terrain after the import. However, the SID imagery is rotated and not aligned to the terrain.
I saw a similar issue described in a post on this forum created 3 years ago titled "Lumen RT Aerial image rotated" but I did not really see a resolution listed for the problem (I've tried exporting an OBJ from InfraWorks but did not get good results).
Looking for ideas.
Thanks!
