Hi, Is there a way to apply transparency to 3SM scalable meshes in LumenRT? I tried to export files from OpenRoads Designer with one or two 3SM meshes attached and transparency levels set to each mesh attachment (as this gives good visual effect for models in cut). But when the file is exported and opened in Lumen RT Pro (Update 14) the 3SMs are shown without transparency. I couldn't find any relevant setting in LumenRT.
Mariusz
Hello Mariusz,
we can not add transparency for 3SM.
Will you please share your test case, so i can investigate further and try to add enhancement and discuss with PM.
Thanks & Rg
Harshad
