I have had trouble when running LumenRT scenes stored on a network drive in keeping the connection to the DGN file that was exported and trouble with reality mesh viewing. Is it best to run LumenRT on a local drive for best performance? Thanks!
Hello Cyrus,
its recommended to have LRT on local drive , else you can set Scene directory path for network drive instead of local.
once scene directory path is set for network drive then there will be no issue .
you can change Scene folder path from C:\ProgramData\e-onsoftware\LumenRT2016.reg
open it into note pad,
change DocumenPath : \\....................\
Thanks & Rg
Harshad
When you say "its recommended to have LRT on local drive", can I interpret this as meaning that the best performance will be with files on local drive?
