as shown in the figure,How do I use this software feature?Could you give me some details about it?
Hello Hitzxx,
you can enable disable shadows for source lights.
Hello harshad,
I want to remove the natural light from the object as shown in the picture, not the light source.Can this be done?
hello Hitzxx,
Yes you can reduce the star to single one and it will show you the shadow effect of the object.
Try this and let us know if it worked.
Thanks.
Rg,
Ankur Ashesh
Answer Verified By: HITZXX
I'm fairly sure the intention is to remove the shadow for ALL render states (one to five stars). It's a similar concept to the previously discussed ideas that shadows could/ should be disabled in various situations (eg. an underground mine, a microscopic petri dish scene, a galaxy far away); communities.bentley.com/.../545004
Hello Max,
We control shadow on source light only.
Its difficult for controlling shadows on object basis as we weld geometry while export from cad product. However i can check if its possible to add ability to enable disable shadows on Level basis.
Thanks & Rg
Harshad
Hello Harshad,
I really hope to realize the function you said.
HITZXX
