Could the model layers be turned on or off in lumenRT LiveCube ?
About LumenRT:
There are some  design scheme in the same scene, so I want to switch the display of different layers in LumenRT LiveCube?   How to do that?
Now, The LumenRT original file has to be exported to LiveCube many times.
Chen Zhengpeng
  • Hello Chen,
    Just to be sure you are can only have the option to play with layers inside LumenRT main file .lrt file source.
    But Publish Live-cube do not have this option, it is non editable file (only to view).
    If you want to play with layers you can control in .lrt file from here,
    I hope this will help you.
    Thanks.
    Rg,
    Ankur Ashesh
