Hi all,
I've come back to an older scene in LumenRT, but I can't find the original CAD file (i.e. OpenBuildings Designer in my case) that was used to create it. I'd like to make a small change without redoing the scene itself. Is there a way of finding the file path of the source file from within the Lumen scene?
Thanks for any help,
Tom
This would be useful (if it existed, but I don't think it does). Assuming you know that the DGN filename would be the same as the LRT, does it not show up when you search for it with File Explorer? I personally find File Explorer's search function incredibly slow and unreliable - so you might want to use Locate32 (a really fast database file search utility).
Hi, thanks for the reply. Disappointing if it doesn't exist. I did try searching through File Explorer, but no luck. I wonder if there's a way of updating the imported model in any other way?
Unfortunately this functionality doesnt exist. The file name is the best bet.
What were you hoping to change? If its a simple update like a new building i would just create an obj of the building or whatever content you want to add and import that into the existing scene.
Answer Verified By: tom pike
