Hi everyone,
I'm using OpenUtilities Subsation, which has a Visualization workflow inside it. I've created an animation script which is working fine. The problem is when I try to record it. It's going way too faster than I want.
To give you a better view:
1. My scrip has 580 frames.
2. I'm using those configurations and exporting to MWV format:
3. I even tried to change the Speed (Tricks/Frame) as you can see in the figure below, but I don't think it's working.
How can I proceed? I wish I could have 1 or 2 frames per second. But for now it's only generating videos of 20 seconds.
Is the playback in the player or the rendered video too fast.
For rendering the animation to a file the FPS is set from the animation settings:
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v17/en/AnimationSettings.html
