Hi All,
I am having issues with exporting Microstation CE (and OpenSite Designer) saved views into LumenRT. From what I have read saved views should automatically be exported to LumenRT and come in the movie editor as an "Imported Clip". I have even created a new sample file with basic shapes and it still doesn't work. Sample .dgn file attached along with screenshot.
Any tips or suggestions on why this is working would be greatly appreciated.
Cheers,
Cam
SavedViewTest4.dgn
Hello Cam,
Which version of LumenRT and Microstation Connect edition you are using ?
Thank you for the file will have a look.
Ankur Ashesh
We have checked you file,
The setting you have used for camera saving image was parallel projection, which will not support inside LumenRT
Can you please use 3-point setting,
And try again.
Please let me know if you have issue again.
Thanks.
Answer Verified By: Cam Livingstone
Hi Ankur,
Perfect, works now. I knew it would something simple like that. Thanks so much for your help.
