The grass sometimes exceeds the position of the map and is inconsistent with the map. How can I solve this problem?
The 3DMAX map model is imported into lumenrt, and the map is given a grass material in lumenrt. However, the grass sometimes exceeds the position of the map and is inconsistent with the map. How can I solve this problem?
