The LumenRT update 16 Wiki suggests the new version will have "Export nested reference structure as it is into LumenRT"
What does this mean? I'm setting up a new project and would like to know if I will be able to control the visibility DGN reference files once the parent DGN has been exported to LRT.
Max
Hello Max,
till last release we use to merge all layers from reference files to main .
Now from Update 16 user will have choice either to export file with merged layers or they can take it separately layered as per references.
In LumenRT layers , all layers will displayed same as MicroStation nested reference structure.
Thanks & Rg
Harshad
Sounds good, thanks Harshad.
I'm curious to know when Update16 will be released
Any announcement on a release should be posted on our MS announcements forum.
https://communities.bentley.com/products/microstation/f/microstation-announcements-forum#pifragment-25830=1
I will inquire to see if the is a general planned release window though
And presumably on connection client? I've sometimes not received notifications even though the download centre has an update available.
Good luck with finding that release window- I was told on June 29th that "we are going to release the LumenRT update 16 very soon".
