Hello everyone,
I'm wandering what is the normal time to export a video from LumenRT.
So I have a file (approximatly 2Go), and I use the preferences you see in the image below.
It took +30h for the video (3min 45s) to get exported, and I was wandering if this is normal?
Best regards,
PS : The specifications of the computer I'm using are below
Hello YoussefB,
Can you please share the Graphics card details, as LumenRT works on GPU not CPU.
Thanks.
Ankur Ashesh
Hello Ankur,
The Graphics Card Details are :
YoussefB
The card is very old and 8GB of Video RAM, with this card it will going to take long time.
can you share your .lrt file with us, I will try to render the same and check the time with new card at my end.
I am using Quadro P5000 card at my end.
Rg,
Answer Verified By: Youssef Boutlane
I will share with you the file as soon as possible.
Regrads,
Sorry mate, but i think it is possible. It looks that this spec are little bit outdated and low performance. Btw i think that Quadro is ok with 3d drawings but for rendering gaming cards are much better. Look at some comparition with my old card ( 2016 ) > UserBenchmark: Nvidia GTX 1080 vs Quadro M4000
