Hello in the Help menu in LumenRT update 16 for VR it states support for Oculus Rift and HTC Vive. Does it also support Oculus Quest 2 using the PC cable? or is this in development? do we expect support in the future?
thank you :-)
Hello Andy,
We are checking the quest 2 right now.
Will provide you some update as soon as possible.
Thanks.
Rg,Ankur Ashesh
Good morning,
is there any news about it? We bought an Oculus Quest 2 thinking that after 4 months the problem was solved, but at the moment LumenRT crashes if Oculus is active and vice versa. Not even the live cube can open with Oculus.
Thank you
Hello Diego,
Oculus Quest 2 will work with Link cable we have tested just now.
can you share with version of LumenRT you are using now?
Rg,
Ankur Ashesh
Hi Ankur,
the LumenRT installed version is 16.16.44.34
Gpu is RTX 3060 with 511.65 NVIDIA driver
I've sent also report ID at crash: DD93C1F9-8389-4979-8C78-44782D4ECA67
Please, tell me if you need some other info.
Thx, D.
Yes it have some issue with Oculus Quest 2 with the build you have now.
We are currently preparing the new build which have this fixed with Oculus,
will let you know as soon as the update is live in Connection client.
