Hi all,
Does anybody knows why the new LumenRT release is using RAM instead of GPU?
I have opened an 7GB .lrt file and hit play animation. My RAM went from 1GB to 47GB. The animation is glitching when playing because of the intense RAM usage.
The usage of GPU is 0%.
PC spec
CPU : Intel core i7 8700k 3.7ghz
RAM: 64 GB
GPU: 2 x Nvidia GeForce GTX 1080 Ti
Does anybody has encounter something like this?
Or does anybody has a solution?
Many thanks in advance!
I'm also using an earlier LumenRT version (16.16.42.87) and don't have this problem - GPU (RTX6000) averages 50% and RAM 20%.
Unless you've typed the incorrect version number in your subject, have you tried using the latest official release (16.16.44.12)?
Max
Hello Alexandru,
Can you please let us know the version number of LumenRT currently you are using ?
and also if you can share some images for the issue and file ? will check that also at our end.
Thanks.
Rg,
Ankur Ashesh
Hi Ankur, after long investigation on my end .I have discovered that I do not have enough VRAM.
Equally I have change the machine as well. See picture.
For my next video card I will use NVIDIA RTX A6000 as it has 16 GB VRAM.
Answer Verified By: Alexandru Vescan
This A6000 card will work for you.
try it out and share the results if you faced any further issue.
