All handles on this scene are the same but some of them are rendered as gray and some them are rendered as white. There was no material assignment/attachment on the handles. Then we assigned material, after then attached material but results are the same.
How can we solve this problem?
Kind regards,
Sedat AlisAEC Technology Inc.
Interesting, what are the handles geometry? Solids, surfaces and are the placed as cells and if so are they shared cells?
Jerry
Jerry Flynn said:Interesting, what are the handles geometry?
Smart Surface with a grouped hole.
Jerry Flynn said:Solids, surfaces and are the placed as cells and if so are they shared cells?
Cabinets are cells and handles are cells inside cells. There is a named cell which describes handle's name. Inside this cell, there is another noname cell but it is made by MicroStation as grouped hole.
Handles are not shared cells.
Handle model is attached. By the way, model's size is extremely big (1.78 MB).
handle.zip
Compare the normals for the good and bad handles. They may be reversed, which can cause rendering issues.
Regards,Ron
I suspected normals but they look okay, I dropped the cell to look and where I expected to see a single solid was a bunch of Bspline surfaces. How was the model created? I know there were some normal issues that were fixed long ago and it seems you are on an older version of ABD, updating might solve issue. I do see something odd that I don't understand one of the surfaces does not appear to be illuminated correctly even though its normal is pointing in the right direction.
Cheers,
Hi Jerry,
When rendered with Luxology, the surface you mentioned appears to float above the rest. I noticed it has a material attached, Metal painted (Dark Grey), that includes displacement.
There are only 2 surfaces that have any material attached. The other surface has a Stainless steel material attached.
