Hi all,
what am i doing wrong with the lights? i want to add a series of lights to the underside of this bridge but after having placed 1, clicking the '+' does not let me add any more, see the image (and gif link for better moving example) below. Any advice would be gratefully received.
Gif link: https://imgur.com/a/ghshq5L
screenshot:
Selecting the 3 dots should allow you to add and additional light, is this not working ?
To add a series of lights make sure that the repeat setting is enabled:
Typically when not on an object will be placed and setting to further define placement will be shown
HI both, thanks for reply but I have ensured both repeat settings and ellipses (to select a light) have been done...repeat setting on and I just click with nothing happening. see this gif (too big for this forum): https://imgur.com/a/rnLaYU5
Any further suggestions? it's driving me mad!
Hi Mark,
There are definitely issues when placing lights in LumenRT 16.16.44.34.
This video illustrates the issues I found.
Regards,Ron
