The 3mx in LumenRT comes out without texture mapping.
It looks good in MicroStation
I am using lumenRT update 16
Hello Cyrus,
Will you be able to share the file with us?
we will check this at our end,
also we do recommend to use 3sm not 3mx snice it have some issue with LumenRT.
If you can get the 3sm for this model it will be nice to use.
Thanks.
Rg,
Ankur Ashesh
interesting to note that the .3mx works well in MicroStation, but the .3sm performs slower in MicroStation.
Problem with 3sm is that it can be Reality mesh or a 3SM terrain. Which one you use?
3mx is less resource hungry than 3sm. Also have noticed that 3sm has issues to read correct LOD level depending on zoom takes sometimes long to view in higher resolution after zoom.
