A simple 3D file - export to SKETCHUP in v8i;
Take the same file and export in CE (Update 16)
Yet another reason why Connect edition fails, and I'm glad to have kept v8i to get the job done.
Max
To add to this - certain element types don't get translated at all in CE, while v8i faithfully translated to CE.
Bentley has broken the SKP exporter in CE.
Please fix.
Still hoping for comments on this, so here's an illustration of the problem.
v8i accurately translates all geometry to SKP, but CE (u16) still fails at this simple task.
Hi Max,
Can you please share this file for the debug the issue?
Pravin Sawant
Thank you Pravin, I appreciate you taking a look at this.
Please also consider the problems with CE that I have noted at the beginning of this thread.
Attached is a sample DGN and the two exports to SKP from v8i 08.11.09.919 and CE 10.16.03.11
SKP EXPORT.dgnSKP EXPORT_from CE.skpSKP EXPORT_from v8i.skp
I will take a look for the problem that some elements missed after exporting to skp.
For the saved view problem, the current 64bit SketchUp API is very different to the 32bit used in V8i. The fit view problem is unresolved till now. The related question was asked in the forum 6 years ago, but never answered …
