When I reference one file to another some graphics disappear please see link below:
(1) Microstation Connect Edition - importing a parasolid & referencing to working file - MicroStation Forum - MicroStation - Bentley Communities
I first thought it had to do with parasolids only but when I import to certain files this happens. I did play around with the visualization setting but it make no difference. Also I made sure to use a 3d seed file but am unable to reference the file (where I imported the parasolids at first) that it displays correctly in my working file.
Johann
Can you send me your files so we can investigate ?
Paul
Thanks Paul, I think it happened due to different worksets. I aligned the worksets of all relevant files (made sure it is the same) then my Tee displayed correctly when referenced.
