Hi, I have a problem with brush size, the minimum size of brush is too large. First it was fine but later l saved and open it became too large, I couldn’t use the terrain for smaller sizes. any idea how to fix this, or the reason for the issue?
The minimum size for the brush should be 1m.
Ayngaran Kanenthirarasa said: later l saved and open it became too large
Were you unable to change the size or was the size still saying 1m but appeared much larger?
Perhaps the local settings became corrupt resulting in the wrong size brush
I can able to change it but it showing minimum brush size is 454.1m
You should be able to manually enter a value by clicking in the field:
under minimum range (454.1) it doing nothing
