Layered material from Microstation CE to LumenRT
I have a Microstation file that has materials assigned to geometry. Some of those are layered materials. For instance I use a color image for a building facade and I've added a layer of bricks to it (blend mode Multiply). When rendering with Luxology it looks the way you'd expect. When exporting to LumenRT using the "Animate with LumenRT" button, I only get the brick layer, and it has the wrong scale.
Doe anyone know of a way to export materials WITH the layers?
Unfortunately I am not in a position to share geometry.
Constructed with V8i: 08.11.09.908
Altered with Microstation CE: 10.15.02.11
Opened with LumenRT: 16.15.74.04
Thanks in advance
(edit typo and formatting)
