Texture planar problem
Hi guys.... I just try simple tram / train / model - very basic
1. I have one long texture
2. The Tram is dividied on 3 sections
Do i need divide texture into 3 too ? I asked because i make some planar texture correct  ( see attached )
Is there any way to lock / permanent block texture for moving when tram is moving / rotating ? I try export to fbx, skp and no success
no matter v8 or Connect
I have strange result in SKP ( texture are moved )
Maybe someone have good idea, tip  or option i forgot..........
