Hi All,
This problem existed in v8i and still persists in CE 10.16.03.11.
With a Raster Reference placed as an underlay to trace and build 3D models, the image appears in a normal View Window with the Illustration:Shadows display style. However, when I export the same view using Save Image then the image does not render. How do I get the image to come through? In some circumstances it has worked, but the image has been very pixelated.
As a bonus, how do I get the shadows projected form the model to be visible on the raster underlay?
Thanks Diego - I have used your suggested technique on some projects, but mostly in instances where the resolution and tone of the underlay are not important.
The problems here are shown below. It really should be possible to save exacly what is seen in the View Window. Image Capture is a potential solution, but limited by screen resolution.
