I have some problem - how to start my train from begining of the path but from frame 600 of total 1100 animation ?
In this case attached - i set start frame 600 but it just disapear and show on 600 and goes from the middle of the track to 1100 ....
Hi martinezx,
Try adding a script entry for the train actor using the Script Actor tool.
It should default to Start Time: 00 and End Time: 1100 or whatever the actual length of the script is.
Regards,Ron
Hi Ron, thanks
but it seems not working ( or i make some mistakes ? )
See attached.
The problem ist still - train starting with all trains ( from beginning 0 )
The Actor should have Time 0-1100The Path should have Time 600-1100(See attached)
Sorry for late answer ( different time )
No succes - still show in other place or start at 600 or 550 but when start - train cars divide and not move together... Maybe the order is important ? Actor , script , path or Actor , path, script actor ? no idea
I tried different settings - can you look at my file ? 37 mb : https://we.tl/t-9q0rvF0Wci
