It looks Lumen is not made for Rail. . You cannot run properly on Track. it does not carefully select rail. In traffic ribbon. The section shows the road and width.
Hello Om,
LumenRT is for Rail to.
What the issue you are facing, can you help me to understand the issue.
Please let me know your free time? I will arrange the session for this.
Thanks.
Rg,
Ankur Ashesh
If possible can you share the files you are working in or provide screenshots of the issue you are having?
Hi, it is just normal track alignment on which want to run your given module of Rail Track Car. You yourself do if it works to make a video and share me.
It is the normal application of Car Body run application on existing Track Design which does not run correctly. There is no such example video also.
