LumenRT element removed from scene.
Hi All, Every time I open scene with LumenRT CE trees placed in Open roads or Any other dgns disappeared. I have message "The scene integrity check has detected some items that could not be loaded. That items have been removed. I tried to place trees in LumenRT same result. May be some had same issue and have a solution.
Thank you.
