Hello, I choose the file:
C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\WorkSpaces\Building_Examples\worksets\Multi-Use_Retail_Building_NM\Designs\A_Grocery-Mezz.dgn
(I am using NO_AVX solution for VUE)
In the model I include a Triform solid, Mesh, linear form, Slab form and free form. They have no part assigned.
I render with Vue and linear form, slab for and free form do not appear.
The rest including Triforma solid and Mesh appear.
View image
If I assign them part (family: Walls_Ext and part: Block Wall) then they appear when rendering.
This is very strange.
Why do they disappear?
Regards.
Antonio
Openbuilding update 9 10.09.01.38
Can you send me the dgn file containing the geometry.
Paul
Hello Paul
The accelerated process can be seen in the video
Render OBD_Up9.1_Error.rar
The file is:
A_Grocery-Mezz_Error_Render_OBD_CE_UP9.1.dgn
You file renders ok for me in Microstation. Is the file version you sent me prior to assigning them to a part/family ?
Have you noticed any difference if you were to place the geometry, then exit and re-open the file and render ?
Paul Chater said: Is the file version you sent me prior to assigning them to a part/family ?
The file is A_Grocery-Mezz.dgn delivered with the OBD_CE_UP 9.1 (10.09.01.38) installation.Located at C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\WorkSpaces\Building_Examples\worksets\Multi-Use_Retail_Building_NM\Designs
A similar problem occurs in all the files on my computer
Paul Chater said:Have you noticed any difference if you were to place the geometry, then exit and re-open the file and render ?
The problem remains the same with that process.
I am using OBD not Microstation (I don't think that is a problem) but I am using the VUE solution for NO_AVX processors (perhaps that could be the source of the problem)
See what happens if no part is assigned or they have no material attached. They do not appear in the VUE rendering.
Linear form, Slab form and free form if they do not have a material attached through the part or through attach material directly, they do not appear in the VUE rendering on my machine. After analyzing this I have seen that this is the problem.
In your rendering appears the spaces. They don't appear in my rendering because the part has no material assigned to it.
See the image the render result.
Linear form, Slab form and free form without material assigned (by part assignment or by attaching material) do not appear in the VUE render
Attaching material everything is solved but it is not a correct operation.
VUE seems better but with Luxology this problem did not appear in my machine.
