I have some questions, is there anything new regarding rendering in 10.17.01.062 and if so what are the implementations/changes?
Regarding the batch render, do you have anything in progress? At the moment you have to launch them individually if you want to take advantage of the post render settings.
Regarding the fix of the area lights (at the moment the panels cannot be made invisible and in any case the dimensions of the area lights do not correspond to the rendered dimension) do you have any news?
Do you have any news on implementing IES lights in path tracing mode (currently not working)?
Do you have any news on the 360° renders in path tracing (currently not working)?
A thousand thanks,
Diego
