using the NPR effects on renders produces 2 anomolies....
1. missing lines or geometry
2. and when applying White Sheet, the background is blue as per the image below
Hi Duncan,
Can you send us your Dgn file to test with.
Paul
Hi Paul,
I have discovered that this is to do with the intel denoiser. If i turn the denoiser off or to NVidia then we get a white background
might be related to a known bug if you havent shared the file yet can you please share for review.
See post above David. This is to do with the intel de-noiser. this is not file specific
