When using Microstation connect update 17.1 and vue to render a scene all text dissapears.
Setting the 'ignore open elements and text' to 'Off' doesn't resolve the problem.
Are there any specific other settings I should check?
Kind regards.
Wim Aerts
Hi Wim,
This seems to be a bug and I believe a TR was filed. As a workaround, if you drop the text it would render as shapes I know true type fonts would render if dropped I have done this before and you can extrude the shapes for 3D text as well.
Cheers,
Jerry
Answer Verified By: Wim - 4Dselect
Hi Jerry,
Thanks for the update. I wasn't shure I was doing something wrong.
I'll definitely try to drop the text.
Regards.
4D select nv
Adding to Jerry's workaround...you should be able to select the text elements and specify a thickness in the element properties.Hopefully this will also make the text render too.
This way you won't need to drop the text and it will remain editable text.
Regards,Ron
I confirm Bug 656846 has been filed and remains open at this time.
Good morning Ron,
That is a helpfull workaround. It worked in my case, Text is again visible!
Thank you
