I exported a 3d model from Openroads designer to skp file. However, there are layers that can't be viewed in sketch up. (eg. road layer)
May i know any suggestion/solution for this.
Thank you.
Hi Sheena,
Can you please share test data to investigate?
Pravin Sawant
Were the layers on when you exported. The skp export should only export elements visible in the view.
https://docs.bentley.com/LiveContent/web/MicroStation%20PowerDraft%20Help-v14/en/SketchUpExportSettings.html
