In V8i it was not necessary to enable the AccuSnap setting Identify Elements Automatically to work with materials, but in Connect Edition it must be enabled. In CE if it is not enabled you can't attach a material to an element. You can't even Query the material unless you enable that setting.
I personally avoid using Identify Elements Automatically because I don't like it. I prefer manually identifying elements. I know this requires more mouse clicks, but I don't care about that.
It should work the same way it did in V8i, but currently it doesn't. It should be up to the user whether or not to decide to use the Identify Elements Automatically setting.
Regards,Ron
Hello Ron,
Will be possible to provide a small video clip showing the difference between v8i & connect edition.
Shivraj
Hi Shivraj,
Here's a video that demonstrates the issue I am seeing.
Hello Ron
Thanks for the Video, I will investigate on your concern and revert back to you as soon as possible.
