For those of you who have had issues with light noise, in the form of those dreaded splotches and blotches, I have posted a blog (bedtime story) here...
Enjoy
JF
Thank you Jerry.
This document was really needed.
Ivo Blaauw
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
the thing that I can not eliminate is the dirty reflection that in this case you see on the floor.
As you can see the floor correctly reflects, balls etc.
how you manage to delete this? thanks for any help
ciao
Hi Alex,
I know what is causing this, it is the shadow sampling on your area lights. Using soft very fine (256 samples) will help. You can see this yourself by setting the shadows to coarse (16 samples) which will produce the most noise.
I would be happy to take a look at your test case too ;-) I might be able to come with some ideas if I had your scene. I suppose we could allow even larger sample values to be used which would eliminate the noise. I'll talk to Paul maybe we can get this into the update.
ciao Alex
Jerry, the file is in FTP, name: TestMartini.rar
Yes and I have sent the scene to the folks over at Luxology to take a look. We have already asked for improved area lights so I suspect we will have to wait on this one. I don't know of a setting that will make this noise go away.
Thanks for the test case.
JD
a little bit combination of solar light, spot light with volume and glow - no s/blotches - exterior good with Env: material preview, set to half, bounces 1 , rays 128 , time 22 min on Core Quad 2,66 ( i think i need more antialias ( used Low )
