maximum image size
a client wants an image for a 8'x4' banner at 300 dpi. i put in 28800 in my image size dialog and i get a memory allocation error. i thought the size constraints were resolved with the latest B2 build [v08110918]. is this not the case? is there a newer beta that i missed?
  • I would question the value of creating a 300dpi image meant for a final output size of 8'x4'.
    Large images like that are usually viewed from several feet away and a such seldom benefit from the added resolution. To the contrary, they take longer to render and print, and often cause problems when sending them to the printer/plotter.
    We normally use a maximum of 150 dpi for posters. This allows us to create displays which maintain smooth, readable text and smooth line work. If the final image doesn't have any text or line work, where aliasing of the edges is most noticable, you could probably reduce the dpi to something like 100dpi or lower and still achieve acceptable results.
    Just because a printer or plotter is capable of 300, 600, or even 1200 dpi output doesn't mean they require(/or benefit from) that resolution in the image being printed. The determining factor for resolution of the image your are rendering in MicroStation should be, "What is the lowest resolution that produces acceptable results at the desired viewing distance?" You can try a small 1'x1' section of the image rendered at various dpi (72, 100, 150, 300, etc...), and plot each out at 1'x1' and compare the results.
    Use the lowest resolution that looks good.
    HTH,
    -Ron
  • Most print houses use 72 dpi
    Ustn since 1988
    SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64b
    Eric D. Milberger
    Architect + Master Planner + BIM
    Senior  Master Planner NASA - Marshall Space Flight Center
    The Milberger Architectural Group, llc
  • thank you both for your replies.  however, i am aware, and have informed the client, that 300 dpi is a bit 'over the top' but they were insistent.  so, what the owner wants, the owner gets.
     so, back to the original question.  anyone?
  • Hi mswede,
    I'm afraid that if you want to render very high resolution images you have to consider to buy more ram and probably a 64 bit version of Windows.
    And even that can't ensure the rendering will succeed. A resolution of 28,800 (I presume horizontal) lines, is very extreem for a rendering.
    Option 2 is to render you're image at for example 150 dpi and increase the size in Photoshop.
  • i have a 64-bit machine and 12GB or ram [probably should have included that info in my original post, sorry ‘bout that]. that is why i am curious about the image size restraints in ustation as i am fairly sure i'm not ‘actually' running out of physical memory.
    anyway, thanks for the reply and the option. i was thinking of doing that if i couldn't get this to work.
