....I've got an external Table of materials ( I know this is an old fashioned concept but it works better for how I model and work).......is there a way of stopping the materials from the external tabel being copied in Local??.....see the image below - this is made up of 4 model files(one for each floor level) referenced into a seperate file
....now I want try options for the brick type/colour - in the old days (prior to the advent of 'Local' materials) this was easy, one would change the brick type and it would automatically update this in all files that referenced that material table (in this case, the 4 floor models) and voila my brick changes. I've tried creating an external table but when i import it into my 'collective' file (with all models referenced) it seems to copy materials locally - is there a way to stop materials being copied locally and 'force' it to use the external table (ie so I have only one place to change a material - rather than in 4 seperate model files)
- before anyone says that I apply materials in a collective file, I also like to see materials previewing in all the individual files)
hope this makes some sense?
thanks
Steve
Marc,
Nothing will break if you have MS_DEFAULT_TO_EXTERNAL_MATERIALS set and work in an area that requires internal materials... areas that require internal materials will all create them on the fly, giving you a mixed palette.
Here's the features I'm aware of that will create internal materials:
1) Material overrides specified in the Level Manager.
2) Materials from OBJ/SKP/3DS files that are imported into a model.
3) Captured GE terrain.
Matt
Thanks Matt, it's ggod to know this kind of thing.
Marc
