Anybody have "rendering & Lighting" tutorials for beginners?
Anybody have "rendering & Lighting" tutorials for beginners? I am using Microstation v8i. If anybody have please post me. Or From where i can get this? Please suggest me... Thanks
Parents Reply
  • Since we use Luxology's rendering engine, some of their tutorial videos can prove incredibly helpful when learning how to render inside of MicroStation.  The UI may be different, but all of the settings talked about in these videos can be manipulated in our Render Settings dialog.  If there's something that they mention that you can't find, it might be placed in the "Advanced" tab, but don't let that scare you!  The "Advanced" tab is mostly just a consolidated list of what you'll see in the normal sections.
    Here's a list of the videos that I found to be useful when I was learning about the Luxology engine:
    Indirect Illumination Explanation: www.luxology.com/.../view.aspx
    Optimizing for Large Resolution Renders: www.luxology.com/.../view.aspx
    Displacement Ratio Discussion: www.luxology.com/.../view.aspx
    Optimizing with Transparent Materials: www.luxology.com/.../view.aspx
    The first on the list will probably prove to be the most useful until you're more comfortable with V8i rendering, but I've found the rest of them to be incredibly helpful.
    HTH,
    Evan
