How do you add new materials to a palette? I have some jpg's that I would like to add for woods and some for plastic laminates
Can someone please post a step by step process
Thank you
Kirk,
Sorry for the slow response, I usually keep an eye on the Visualization forum for these kinds of questions. Hopefully this is still useful to you!
If you want to add a material to an existing palette, click either on the palette or on one of the materials in the palette where you want your new material to be and then go to Material -> New.
This will create a new material inside the palette, but the material is currently stored locally and will not be available once you move to a different file.
If you right click on your new material, you can choose "Copy to Library" which will add the material to the .dgnlib that houses the palette.
When it's successfully added to the library, the icon will change to this:
From here you can start working on your actual material. The first step here will be adding a pattern map, which you can do by clicking on the checkered box next to the Color slider.
From here there's a lot that can be done and you can find some insight as to what all of these settings are by looking at the documentation and by browsing the MicroStation Visualization forum.
The Visualization forum is located here: http://communities.bentley.com/products/microstation/microstation_visualization/default.aspx
HTH,
Evan
HI Evan,
I like this thread too, May you capture this as a wiki page in Visualization forum, it helps rookies like me a lot.
Frank
Hi Frank,
I'm glad this is useful to you! I'll definitely consider getting this together for the Viz wiki and maybe looking at some often overlooked barriers to entering the visualization world.
Nikolay Vyglazov
